NO spin cycle
I believe the clothes washed ok and then the machine did not spin.
It made a not so loud noise will on spin like a growling noise. Can you tell me the main thing to check and possibly the next thing or 2 in case the first doesn’t fix it. IS it worth trying to fix at this age? Probably depends on cost of parts and difficulty to repair.
If its time to get a new washer, any opinions based on your expertise in repair. Would you recommend a brand or model, for reliability, ease of repair etc.??
Thaks for your assistance. These forums are a fantastic resource.
Barry D
Barry,
The first thing I would check is the motor drive coupling (#13 on the diagram). The complete instructions are attached.
Here are the break down diagrams and Replacement parts for WHIRLPOOL LSR5233AW0 | AppliancePartsPros.com
How to replace the motor drive coupling.pdf (39.5 KB)
How to remove the washer cabinet.pdf (43.5 KB)
How to remove the pump.pdf (42.3 KB)
