No Power
The microwave has no power to the control panel. Checked breaker box, it’s ok. The interior light DOES work. The work light, fan and control panel are dead. I found the parts lists and simple diagrams but my problem is that I don’t know how to get to the FUSE inside the unit. The diagram looks like the FUSE is behind the control panel on the right side of the unit. I need help removing the panels to access the FUSE. Thanks.
If the interior light does work then there is nothing wrong with the fuse.
Most likely the problem is a bad control board.
In order to get access to the parts behind the control panel you have to remove two screws holding the top panel (aka vent grill) first and pull the top panel toward yourself.
Remove the screw on top of the control panel, slide it up to release from the tabs and pull it out.
