My Dryer had the “AF” show up and found the pulley had fallen off. After i got the pully back on i pluged it back in and the screen started to light up and would not turn off. The dryer started to get hot so i unplugged it. Now when i plug it back in NOTHING turns on, no lights nothing. What should i check first?
Hi.
First check for 240VAC at the outlet. If no power - reset the breakers.
Check if the thermal fuse on the top of the blower housing is open. Replace if needed. Check if the blower belt is on.
With the power off check the control board heater relay contacts NO and C for continuity. Take one wire off when checking. If there is continuity at the power relay you need to replace the control board.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5512112
Post the results.
Simon.
