I was having a problem with the door staying closed although fixed most of that problem by installing a new balancing kit. Since then the door will not latch and stay closed - the door is staying up but will not latch it keeps poping open and now for some reason the dishwasher has no power?? I checked the circuit breaker which is fine and power is flowing to the unit but no lights are on and it will not power on?? Any suggestions for the two issues or are they both related??? Help???
Replacement parts for WHIRLPOOL KUDS01FLSS6 Undercounter Dishwasher | AppliancePartsPros.com
Sounds like a problem with the door latch itself.
Before opening the door up to check the latch I would check the strike (Item 31 in Section 7) to be sure it is not bent etc.
The two problems are probably related as the door interlock switches in the latch are probably not closing.
I checked the strike does not appear to be bent and appears ok??!! Still no power on the panel would that be normal?? Heading to the kitchen to check the interlock switches! Help again please!
[quote=djs3555;299790]I checked the strike does not appear to be bent and appears ok??!! Still no power on the panel would that be normal?? Heading to the kitchen to check the interlock switches! Help again please! Next step for me might be the shed!! LOL
