No Power to MV after door switch replacement
Brand:Maytag
Model Number: Mmv5219ds-2
Main Symptom: No Power
What happens & when: Replaced three door switches, confirmed thermal fuse is good and breaker is functioning, No Power. What are the next troubleshooting steps?
Check the fuse. It is located where the power cord attaches to the noise filter.
so, different than the thermal fuse? Can you share a diagram?
techsheet-w10844812-reva.pdf (449.8 KB)
Follow the power cord.
Outstanding, Thanks! Normal operation
