Greetings!
GE Profile Microwave/Convection, over the cooktop.
After reapplying power to kitchen appliances after a brief vacation, the micro will not accept power. (I always throw the breakers to avoid possible surge damage.) The unit worked perfectly the night before I threw the breaker.
Voltage to the receptacle is normal. The oven is dark!
I assume there is an internal fuse. If so, that should be my first test. Can anyone confirm a fuse? Any idea where it is located? Will I have to remove the oven from its perch above the cooktop to troubleshoot?
Thanks in advance!
Jay
