No power, no display
Brand:Amana
Model Number:AER6303MFS2
Main Symptom:No power, no control board display
What happens & when:Tripped Circuit breaker/fuse on panel & unplugged unit. Purchased new control board….no power, no display. However, if I turn on ANY burner, the clock display will show “flashing 12:00” yet burner will not engage or fire up.
Error Code (if any):None
Parts or tests already tried:Purchased new control board from Appliance Partspros
This sounds like an electrical issue with improper voltage going to the range terminal block. Pull the unit out, find the power cord and check voltage with a multimeter at the terminal block. The white wire should be attached to the center lug at the terminal block. Black to white should read 120 volts, red to white, 120 volts, red to black, 240 volts. If you are not getting these readings, there is an issue with the house voltage going to the range.
Based on the information packet taped to the rear of the unit, this Amana is a 2020 model. The unit has been fully operational until about 1 week ago. No problems whatsoever until that time. No current changes with the electrical circuit/fuse panel. Voltage is needed to be tested?
Anytime I hear of wonky activity as you describe, I start with voltage. Let’s check it so we can eliminate that as a problem.
Ok…I have a multimeter set to check first voltage. The plug outlet is a “floor” type. I placing the probes into the outer openings while power is on, correct?
Go to the back of the range if you can, find were the power cord attaches to the range terminal block, it is easier to check it there than at the floor house plug.
I have attached pics & images to this discussion
Set your meter to AC volts, 240 range.
Here’s are the results I’ve been able to get:
RED - BLACK = 123 V
RED - WHITE = 123 V
BLACK - WHITE = 288.7 V
If you are reading 288 volts on the black to white, there is a problem with your house electricity. You should be reading 120 volts. Red to Black should be around 240 volts. Have an electrician check it out.
