No Power-Dryer
My Whirlpool Duet shows no signs of power. I have checked the breaker, reset it, let it unplugged for a while, plugged it back in, and still no signs of power. How do I diagnose the faulty component?
Replacement parts for WHIRLPOOL GEW9250PL0 ELECTRIC DRYER | AppliancePartsPros.com
Also here is a manual which should be close to your unit.
L-69 Whirlpool Duet Gas & Electric Dryers Service Manual - ApplianceDigest.com
First thing to check is the power.
L1 to L2 should be 240 volts
In your case Neutral to L1 is the important side.
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
GEW9250.pdf (356.1 KB)
