Some of the icons on the display would not light up during startup. Next time using the icons(display) nothing would light up or work. Is it the control panel or the control board. I want to fix it only once.![]()
Thuper,
If you only want to fix it once, you’ll need to remove the control panel and check the ribbon tracer insert ends for each button when you press it. No 10,000 ohms on any check, would indicate a bad key pad and will need to replace the control panel.
Heres some helpful information for testing,
[ATTACH]3082[/ATTACH]
Good Luck,
16026393.pdf (892.6 KB)
