No lights, water in tub
no lights on panel. water in tub. seems like there is no power to it. I replaced panel a few months ago (Thanks Gene!). Cirvuit breaker in house is ok.
Thanks,
Pete
Replacement parts for WHIRLPOOL KUDM01TJBS0 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208269519.pdf
Did you replace the thermal fuse Item 6 in Section 2 when you replaced the board?
Also did you use the new harness that comes with the fuse when you replaced the board?
Remove the fuse and check it with a meter, should be 0 ohms.
The board did not come with anything else but the entire control board and wires. The info attached does not tell me about a fuse/circuit breaker same for parts.
Now I see it, sorry. Will order fuse. thanks
