Suddenly our kitchenaid dishwasher doesn’t work. There are no lights on the control panel and the circuit breaker has been checked. I’ve seen other websites suggest replacing the thermal fuse for other dishwasher models but I haven’t been able to find such a prt for this dishwasher. Does it exist? Other suggestions?
Thanks in advance.
Parts for KitchenAid KUDC10FXSS5 / - AppliancePartsPros.com
There is no thermal fuse that fills power to the unit in this one.
Check for power where the unit connects to the line.
Check that there is not a provblem with the wire nuts which most likely attach it to the line.
Have you tried flipping the breaker off for a couple minutes to see if the unit will reset itself.
I did turn off power from the fuse box but maybe not long enough. We had a power outage overnight, no idea how long, and now the dishwasher works. Thanks for your reply.
