No lights on control board
Our dishwasher has stopped working. No lights on control board. Have checked the door switch and thermal switch. Both check ok. Before I spend $100+ on new control board, is there a definite test to make sure thats the problem??:confused:
Problem solved. Found electrical schematic on toe plate. This had more trouble shooting instructions. The problem was the control panel not the electronic control module. Appliance Parts Pro is great. Was able to order the part and it arrived in 2 days. The best thing is if it didn’t work you can return it for full refund less shipping.:wink:
