No light when fridge is opened
Brand:GE
Model Number:GTE18DTNDRWW
Main Symptom: No light
What happens & when: Light does not turn on when opened
Parts or tests already tried: Switch tests good
For your GE refrigerator model GTE18DTNDRWW, since you’ve already tested the door switch and it checks good, I’d focus next on the LED light board (GE WR55X43825 Refrigerator Main Control Board With Led Lights | Genuine OEM Part), its power supply, and the wiring.
Looking at your picture, this is an LED circuit board rather than a traditional light bulb. The LEDs or the circuitry that powers them may have failed.
Here’s what I’d check next.
1. Check the LED board connections
Unplug the refrigerator before starting.
  • Remove the LED light assembly.
  • Inspect the wiring connector for loose terminals, corrosion, or damaged wires.
  • Make sure the connector is fully seated.
2. Check for power to the LED board
Your photo shows several labeled test points:
  • 5VDC
  • TXD
  • RXD
  • RST
  • GND
  • NON-ISOLATED
These are circuit-board test points, not necessarily the refrigerator’s incoming power connections.
Important: The board is marked NON-ISOLATED, meaning its circuitry may be at a hazardous voltage relative to ground. I would not recommend probing these exposed contacts while the refrigerator is plugged in.
Instead, use the refrigerator’s wiring diagram to identify the supply terminals at the LED assembly connector and the expected voltage. Don’t assume the board receives 5 volts simply because there’s a 5VDC marking.
3. Check the results
Once the correct supply voltage is identified and safely measured:
  • Correct voltage reaching the assembly, but no light: The LED board is likely defective.
  • No supply voltage: Check the door-switch circuit, wiring harness, and control-board output.
  • Intermittent voltage: Look for a loose connection or damaged wiring.
My recommendation
Since the door switch has already tested good, the LED light assembly is a reasonable suspect. However, I’d verify its power supply before replacing it.
One question: When you open the refrigerator door, are all the interior LEDs completely dark, or do any of them flicker or glow dimly?
That will help narrow down whether we’re dealing with a failed LED board or a power supply problem.
I have attached a section from the service manual about the LED’s and what it reccomends
There are no lights on when opened. Is the circuit board available?
Yes it is in stock and ready to ship. Just follow the link I sent you above (GE WR55X43825 Refrigerator Main Control Board With Led Lights | Genuine OEM Part)
Thanks Jeffrey. I’m going to swap out that board with one I know works first. I take care of 60 units here, almost all identical appliances.
It was indeed the circuit board. Thanks for your help!
