No ignition after interior clean and belt replacement
I OPENED UP THE GAS DRYER TO REPLACE THE BROKEN BELT AND TENSIONER PULLEY, I ALSO REPLACED THE WORN OUT DRUM GUIDE SLIDES FOR ABOUT THE 3RD TIME. AFTER I OPENED UP THE INTERIOR I VACUUMED OUT THE COMPLETE INTERIOR USING A BRUSH AND VACUUM. AFTER EVERYTHING WAS CLOSED UP I TURNED ON THE DRYER EVERYTHING WENT ON EXCEPT THE HEAT. WHAT HAPPENED? THE HEAT WORKED BEFORE.
THANKS IN ADVANCE
BEEK :confused:
THANKS IN ADVANCE
BEEK :confused:
Read more: http://forum.appliancepartspros.com/dryer-repair/449167-no-ignition-after-interior-clean-belt-replacement.html#ixzz1qHOk2Q5P
Sorry, didn’t catch that. Say it again, a little BIGGER!!
