HI I have a Kenmore Elite 665.1593900 and the trouble with it is I have no heat does not clean and does not dry on heat. Use too when I open the door it I would get hit but the steam but nothing now. And does anyone have a TROUBLESHOOT MANUAL for this model.
Check the heater and the hi-limit thermostat for resistance/continuity with a meter.
Always remove power from the machine otherwise you could blow your meter.
Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
