No hot water in Maytag washer
Hello,
I anyone would be so kind to assist me I would greatly appreciate it. My maytag washer model mav208daww does not dispense hot water. Only cold. I have already replaced the inlet valve and it has not corrected the problem. (luckily I can return it) I have been doing some reading and seem to think it could be the temperature switch or circuit board. Anyone have any thought? Thanks for your time!!
Could be the temp switch or the timer. Disconnect wiring from temp switch, set to hot/cold, check continuity between terminals 17 and 19 or just jump out the orange wire and white/blue wire and see if you get hot water in wash cycle. Rinse cycle is cold only.
Eric
