No heating elements work on cooktop or in ovens everything else is still working
none of my elements work in both ovens and cooktop we checked to make sure it wasnt in sabbath mode and it wasnt i was just wondering if any of you guys have run into this
Sounds like a power problem.
The light, control board etc. all run off of half the line 120 volts.
But all the elements require the full 240 volts.
The 240 is controlled for the oven by the control board and the stove top elements by the individual infinite switches so it is near impossible for all the control devices to go bad at the same time.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR]
thank you your advise was right on i had lost power on half the plug nd cycling the circuit breaker fixed it , thank you so much
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
