No heat
Our propane gas dryer no longer produces heat. All other functions work fine. Ducts and vents appear clear with positive air flow. Gas line is open…haven’t checked for a flame or any fuses, etc. What would be the proper first steps to take? Thank you!
I checked the vent going out the house and found it clogged, and hence my problem. I ordered a new thernal fuse and learned I may want to replace the “Safety Thermostat” as well. Is a “Safety Thermostat” and “Thermal Cut Off” the same item? Do I need to change the Thermal Cut Off and the Thermal Fuse, or is the fuse likely enough - I ask because this site is out of the cut off item?
