No Heat
Can Anyone Guide Me. I Removed Entire Heating Element With Thermostat And Modules Still Attached, Also Removed Thermal Fuse And Took To Nearby Appliance Store To Get Tested. The Thermostat Seemed To Be At Fault. Replaced It,put Back Together And Coils Were Red Hot With Heat. Good To Go. Wrong! Apparently While Drying First Load I Lost Heat Again. Who Can Help?
just a quick question did you check your vent pipe for obstrutions could be going off on limit due to poor air cirulation quick test un hook from vent pipe and try operating in well vented area
