No heat
check heating element was good, change cutoff thermostat, fuse thrml.and the thrmst-fix change all the thermostat, still no heat need help what else can be wrong
Check for 230 volts across the outer pins of the input power terminal in the back.
[QUOTE=richappy;105326]Check for 230 volts across the outer pins of the input power terminal in the back.[/QUOTE]
could you tell me what to look for and wher
In the back of the dryer, wher the power cord enters.
