No Heat Whirlpool gas dryer
We have a whirlpool duet front load gas dryer model WGD9400SB0 and it has minimal heat (and now no heat) in the drum and blowing from the exhaust port to the rear. I have cleaned and removed the vent tube, cleaned all lint I can see thru the rear exhaust vent, run the dryer with the air flow venting into the laundry room. I no longer hear the click of the igniter. The dryer is 5 years old and has been in this same room for all 5 years. What is the most likely cause, please.
Hi Criss,
Perform the test# 4 as described in the Tech sheet (page 6). Post the results. The Tech sheet is attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL WGD9400SB0 GAS DRYER | AppliancePartsPros.com
Tech Sheet - W10110638 Duet Sport WED9200SQ.pdf (641.5 KB)
