No heat on timed dry, heats on automatic dry
On my whirlpool dryer, I get no heat to dryer on the timed side of dial, but the timer does move forward.
It does heat on the “automatic dry” side of the dial, but does not shut off when dry.
Any ideas anyone?
Thanks!
Parts for Whirlpool WED4800XQ0 Dryer - AppliancePartsPros.com
[COLOR=“Blue”]It does heat on the “automatic dry” side of the dial, but does not shut off when dry.[/COLOR]
Does the timer advance or just stay where it is set?
Set the timer to timed dry where it does not heat.
Then unplug the unit.
Check the A to B contacts on the timer, should be 0 ohms.
Note that it is a good idea to disconnect the wires from one side. This ensures that you do not read an alternate/parallel circuit path.
Also use the most sensitive meter scale, usually 200 ohms.
the timer does NOT advance
The problem may be the contacts in the timer.
Th heater circuit is the same in both timed and auto so that is why I suspect the contacts are not closing during the auto (a different place on the timer cam).
As far as timer advancing.
In timed dry the timer motor gets power through Timer Switch 0 (T to X).
X is connected directly to L2. T connected to one side of the timer motor withthe other side of the motor connected directly to L1.
In auto the timer motor gets power through Timer Switch 0 (T to F). Also it only gets power when the heater shuts off.
so should i just get a new timer?
I would use a meter and check it first.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
okay, with dryer unplugged, I do not get 0 across A to B, others (T-X and T-F) I get O.
Do I need to get new timer
Thanks so much for your help so far!
Yes you need a new timer
