No heat from oven or stove top eyes
my oven and all four eyes will not heat up and there is no heat indicator light on anymore.
Replacement parts for MAYTAG MER6750AAB Range - Accellis 2x | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag_library/docs/16010419.pdf
Since the stove top and oven have seperate control dewvices it sounds like a power problem.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
