My dryer stopped producing heat recently. We also noticed shortly before the heat went out that the dryer would randomly turn itself on occasionally. I didn’t piece these two things together until recently. Anyway, I’ve done extensive testing and parts replacement on the dryer, but there is still no heat.
I’ve performed the following tests:
- Tested voltage at outlet, 240v L1 to L2 OK, 120v L1/2 to Neutral OK
- Tested voltage at terminals, 240v L1 to L2 OK, 120v L1/2 to Neutral OK
- All thermostats continuity OK
- Thermal Fuse continuity OK
- Heating Element continuity OK
- Flipped the breaker switch a few times just to be sure
I replaced all thermostats, thermal fuse, the heating element, AND the timer. Still no heat, but the dryer turns on. I’m out of ideas, what else can I check?
