No heat after installing new style timer kit and harness
Brand:Speed Queen
Model Number:ADE3SRGS175TW01
Main Symptom: no heat
What happens & when: Original timer would stop mid cycle. Tested timer per your YouTube video. Timer was bad. Ordered part kit for new style timer. Order # 16688223. After installing there is no heat in the dryer. Trying to figure out what caused this no heat condition. Had heat before installation.
Error Code (if any):N/A
Parts or tests already tried: AP7226910 (D519156)
With the wiring having been replaced as well it would be recommended to double-check to make sure that all the wiring is connected properly.
That has been done multiple times and every connection is connected where the old connection came from.
You will want to test for 120 vac at the timer for the heater circuit. Unfortunately, I do not have a wiring diagram to show which wire to test.
