No error code panel not working but clock does
Had a bad rain storm last night and lost power for a second.
Have a working whole-house surge protector.
Our Amana electric Evenair Convention range is now totally weird.
The clock is on but I can’t set to correct time.
No buttons work on the panel
When you open the door the light comes on
I turned the master fuze (outside) to off and then back to on and it did nothing to fix the problem
Is this a relay board or computer part that can be replaced.
Thanks for your help with any ideas…from this housewife in San Antonio!
Parts for AOCS3040E - AppliancePartsPros.com
You will have to choose the correct unit from the Matching Model Numbers section.
Unfortunately it looks like the control boards are obsolete.
Hoe long did you remove power from the unit?
Perhaps give it a few minutes.
AOCS3040.pdf (247.6 KB)
