No Display
Hello, last year my wife and I downsized to a smaller house. The house had a Bosch SHY56A05UC/14 dishwasher that was known not to be functional. So for the last year we have been hand washing everything. Anyway, I thought it might be time to look at repairing this if it isn’t too expensive.
The problem I have is that the red power light does come on when turned on but nothing else. There is no display at all. I read where it may be an issue with the door switch but after removing the switch and doing a resistance test on the switch it is working fine. I then removed the control panel but cannot see any obvious physical burnt solder joints on the board. Is this board still the most likely culprit or do I need to look at something else?
Any suggestions would be appreciated.
Check if there is proper (about 120 VAC) voltage from the On-Off switch to the control module while the door is closed and the “On-Off” is in On position.
If the voltage reading is correct, replace the control module.
Here are the breakdown diagrams and Replacement parts for Bosch SHY56A05 UC/14 (FD8301-) | AppliancePartsPros.com
Thanks Gene. I did check the voltage and yes the contol board is receiving power. I suspect you are right about being the board. Even though I still don’t have any display if I wiggle the connector at the control board that is receiving the 120 volt from the door switch it starts to cycle on and off.
The control board is the culprit. No doubts about it.
