A little water spilled and got under a knob of our Modern maid stove KGT693. I unplugged it for awhile, and now none of the four knobs make a clicking sound when the knob is turned to lite, although the burners can be lit with a lighter. The fan still works fine. I cannot find any indication of what replacement part I might need. Help
Tear apart console, clean out all the water you spilled. Check for power leading into the spark module that’s more then likely the culprit but make sure you get all water out of the console and check for burn or smoke marks.
