No air flow
My dryer will heat the clothes and spin however the air does not flow so all I have is very wet hot clothes
Check to make sure your vent pipe is not clogged. THat is a common problem. Make sure it is clean and clear all the way to the outside. Also make sure it isn’t pinched or kinked in any way. :eek:
Could be the blower wheel has stipped out internally and is no lo loneer turning when the motor turns.
Could be something has fallen into the blower assembly.
Strange that it did not blow the thermal fuse.
