New Whirlpool Dishwasher
I have a brand new whirlpool dishwasher that seems to be leaking between the door and bottom panel in the middle. It just looks like water had settled there, but when i dried it up the water came back.. I havent noticed this before.. so wonder why it would be doing it now??? Is there an easy way to check to see what might be wrong???
Please help.
Thanks!
I would check the level of the dishwasher. It should be pitched back slightly (front higher than the back). If you’re pitched forward even a little water will pool in front of the door and leak.
If you have very hot water >140f check to see if the washarms are splitting at the seems.
