Brand:lg
Model Number:WT7500ce
Main Symptom:
Photos / video link:I bought a new controller board board w
Same part number as the old one but when I put it in I can’t start the machine display is dead when I put in the old one it worked did that with 2 separate boards so pretty sure not a dead board
First, I would like to ensure that you have the correct part for your LG washer, model WT7500CE. According to the parts information available, this model uses part number EBR81634304, which has been superseded by CSP30042102.
If you can confirm that this is the board you installed, I’d like to gather a little more information:
What was the original issue that led you to replace the control board?
Have you found any damaged, loose, disconnected, or missing connectors, especially in the wiring between the main control board and the HMI (user interface/display)?
Is the new control board receiving proper power?
Once I have that information, I can help narrow down the cause of the problem and recommend the next troubleshooting steps.
