New soap dispenser
[LEFT][COLOR=#000000]Just installed a new soap dispenser on my quiet partner III.
Is the door to the dispenser supposed to open as soon as the start button is pushed? Model # GU2500XTPS
That is what is happening.
Thanks,
Mike
[/COLOR][/LEFT]
Replacement parts for GU2500XTPS models | AppliancePartsPros.com
No it should not open till the main wash cycle starts.
See the attachment for a tech sheet which shows the cycle timing.
It sounds like a control board problem.
I would check that it latches properly and that just the water hitting it during pre-wash would not open it.
GU2500.pdf (161.3 KB)
