Brand: GE Model Number: Part number GE 175D2307-P018 Main Symptom: mechanical timer control not advancing What happens & when:
Error Code (if any): There are no error codes the machine is analog, not digital
Parts or tests already tried: The mechanical timer switch is brittle and cracked so it no longer stayed anchored to the control console. I replaced the part and installed it. The replacement switch does not appear to advance. I set it to the wash cycle and the drum fills to the appropriate level and then the cycle does not continue, it does not advance to wash.
If I advance it manually it will go to drain and spin --though sometimes it resumes filling while spinning. It continues spinning until I advance it manually again. I suspect the switch itself is faulty but wanted to check before I try to return and replace it.
Thanks!
Photos / video link: Here’s a picture of the switch that I replaced with the exact same part
The timer used in this model is a “step” type timer, which can appear as if it is not advancing for about 3 minutes where it enters into the next “step” and will appear to advance. Is the washer failing to advance after 3 minutes?
If you have a multimeter available, the timer motor can be tested for 120 Volts AC to identify if it is receiving voltage or not. After the washer fills, test from the violet wire (goes from the pressure sensor to the timer) to the solid orange wire. If there is 120 Volts AC present, does the disk in the timer motor look like it is spinning?
I will try that, thanks. Unfortunately this machine is at my summer house and I’m not planning to be there for a few weeks. I’ll try asap. Just want to mention this is a brand new switch I just bought.
Hi, finally back to my house so I could follow up here. The switch is getting power. I put the old switch back and it works fine. I am replacing it because the housing on the old switch is broken and I can’t mount it to the washing machine’s dashboard.
Given that the old switch does what it’s supposed to do and the new one doesn’t, can we conclude the new switch is faulty? Can I send it back for replacement?
