New ice maker not making ice
Brand: jennair
Model Number:jfc2089hes
Main Symptom:New ice maker not making ice.
What happens & when:still no ice after 72 hours and freezer stable at 5 degrees F
Order #17549974
Error Code (if any):none
Parts or tests already tried:D7824706Q
With the freezer holding steady at 5°F, the new ice maker should have started producing ice by now. While 0°F is the recommended freezer temperature, 5°F should be cold enough for the ice maker to cycle.
Before replacing the new ice maker (D7824706Q), I would check the following:
  • Shutoff arm: Make sure the metal arm is fully lowered into the ON position.
  • Ice maker mold: Check whether the mold is empty, contains water, or contains frozen ice cubes.
  • Fill tube: Check behind the ice maker for an ice blockage preventing water from entering the mold.
  • Wiring harness: Unplug the refrigerator and make sure the ice maker harness is fully connected and none of the terminals have backed out.
  • Water inlet valve: Verify that the water supply is turned on and the supply line is not kinked.
The ice maker can also be manually cycled using the T and H test points on the ice maker module to determine whether it will harvest and call for water. This involves live voltage, so I would start with the preliminary checks first.
A few questions:
  • Was the original ice maker experiencing the same problem?
  • Is the new ice maker mold completely dry, or does it contain frozen ice cubes?
  • Have you heard the new ice maker cycle or attempt to fill with water?
These answers will help determine whether we have a defective replacement ice maker, a water supply issue, or a problem with the power supply to the ice maker.
