Kenmore model 110-2112012 on start no water coming in motor starts a d then stops no volt to water inlets valves two black wires to water vacuum break have 120 volt all motor leeds other than whit:D e one have 55 volts at control board
Hello,
If the washer is less than a year old then don’t do anything and call Sears for the warranty service.
The model number you posted does not come up.
