New bake element pre heat takes 40 min
Put In new Bake element (old one broke and burnt out) first heat cycle it took 40mins to pre heat to 400 turned off oven for a few hours tried again at 350 took 40 min again any suggestions.
1Lions,
Does the broil element work properly ?
You may have a damaged or shorted wire in the cabinet back wall wiring harness.
Do you have a multi meter, so you can check to see if you have 220 VAC. across the element terminals in a bake cycle ?
That’s where I’d look or test first.
Good Luck,
