Dryer has sensor dry option that does not seem to work anymore. If put on time dry it dries the clothes but takes longer than it should. It’s run this way for quite a while. It now squeaks too.
Check you venting for obstructions and clean out any lint inside the dryer especially check the rollers. See if that helps.
Nat
