My dryer sounds as thought there is a rattle in the rear as the dryer is running. This just started. Is this the sounds of a bearing that needs to be replaced.
Regards,
RED
It could very well be the 2 drum rollers in the rear, or idler pully, which is what the belt goes around. If you were to go the time to take it apart, you might as well replace the 2 drum rollers, the idler pully and the belt, and of course a good vacuum out, would be great. Tom
Tom,
Thank you for the information. I will do just that.
Regards,
Bob
Good Luck. Tom ApplianceEducator.com
