Neptune control panel problem
Maytag Neptune 5500, what causes R53 R54 R55 R56 resisters to over heat?? maybe a bad contenction somewhere???
I have the exact same problem with the same model. I replaced the control board, and after running fine for a week, the dryer went into a permanent pause, and I suspect the same resistors are burned.
