Needs information
my dishwasher continue running, and does not stop even after end cycle , any sugestion please.
Hi.
If the timer is advancing to the end of cycle and the dish washer still running, then most likely the problem is bad timer.
It’s relatively easy to replace the timer.
The timer [PART]AP4112794 [/PART]
Here are the breakdown diagram and Control panel replacement parts for Maytag DWU8860BAM DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
Thank you . Post the result.
