NeedDryer is not drying clothes all the way, takes 2 cycles to complete (over 2 hours
It take at least two cycles in order to get my clothes all the way dry. I have cleaned the lint hose out, and vacuumed the area under the lint screen, but she is just not heating like it used to. Even rubbing it a little, won’t make it hot. If it is the heating element, do you have a manual that shows you how to replace the element? What else may be wrong with it. It came with no diagrams at all, so I will need a diagram for whatever you may think is wrong with it. Thank you for your time.
Sincerely,
Mr. Lee Bolin
Hi Lee,
Measure resistance between Heater terminals 1 & 3,1 & 2 and 2 & 3 and post the results. The disassemble instructions are attached.
Here are the breakdown diagrams and Replacement parts for LG DLE7177WM Dryer | AppliancePartsPros.com
Cabinet cover removal.pdf (128.2 KB)
Control panel removal.pdf (123.8 KB)
Top plate removal.pdf (86.3 KB)
Tub drum and drum assy removal.pdf (119.6 KB)
