Need to test thermostat
My freezer has iced up twice and worked again after we removed the back panel and allowed it to melt. Everything I see on this site says to check the thermostat and heater (which seem to be the defrost assembly) and if they are fine, the defrost control board needs to be replaced. I have a digital multimeter. How do I test the defrost assembly?
Here are your parts includes a wiring diagram.
Replacement parts for MAYTAG MSD2356AEW REF - SXS/I&W | AppliancePartsPros.com
Defrost heater with thermostat is Item 12 in Section 4.
The defrost thermostat is wired in series with the heater so you measure them both at the same time.
You should have 3 wires at the plug.
One is a defrost side, one is the heater side and one comes from the connection between the two. See the wiring diagram.
The thermostat is 0 ohms when frozen and the heaters are usually around 20 ohms.
Use a 200 ohm meter scale.
The defrost thermostat must be frozen for it to be closed so you will have to hold it’s face on an ice cube to freeze it.
If the defrost thermostat is bulged or deformed it needs replacing even if it measures good.
[quote=denman;406708]Here are your parts includes a wiring diagram.
If the defrost thermostat is bulged or deformed it needs replacing even if it measures good.[/quote]
This is wonderful information. The only thing I don’t know is how to hook up the meter. Do I have to detach a wire or just hook it to the prongs on the plug? Thank you.
Yes.
Be sure the unit is unplugged whjen measuring ohms.
Following is my little blurb on meters.
