Hi, I need to replace the door gasket on the freezer, but I can’t find a replacement gasket. I have no idea how old the refrigerator is. I am assuming it is anywhere from 5-15 years old. It is a JC Penney Model number 867 0616 42 90.I can’t find any info on it at all. Is there like a universal gasket that you can buy or something, or do you need one specific to this model? Anyways, any help would be greatly appreciated.
the only way i would suggest you replace your gasket is with one specific to your model. there are cut and fit kits available, but they are EXTRMELY difficult to use. If you are unable to find an original replacement from your local appliance parts store, or if it is no longer available, then you have no options, at least none that I might have for you anyway.
