Need to replace a broken infinite switch
Hi folks,
I have a Jenn-Air cooktop that has a broken infinite top burner switch (I think it is older than 10 years). I opened all the panel in order to replace the bad switch.
The problem is that I can’t find the part number. I see some numbers but it does not look to be the right part number as I can’t find useful information or parts on the Internet.
Here are some pictures:
Index of /jenn-air
I would like to know the part number of my switch and some advices would be much appreciated.
I wanted to compare the broken switch to the three other working switches, but I have figured out that they did not have the same pin numbers. The broken one has 5 pins total, as the three other have 6 pins.
The three working switches are INF-240-C707, and I can find them on the Internet.
Help please!! :frowning:
Thank you guys
Charles M.
I did some searching and found the following cross reference, see the attachment.
240-1130 crosses to 5500-202
If I then look that number up I get.
AP5645804
Click on the picture for more views.
Note that I am not 100% sure on this but it is the best I can do.
Switch Cross Reference.pdf (8.9 KB)
Looks like the good part!
Thank you!
