Need to locate drain pump filter
my Amana washer model nfw7600xw won’t drain. i think i need to clean the drain pump filter but do not know where it is or how to access to it. is there a repair manual i can view to get instructions?
Remove the access panel below the door. It’s held on with screws at the bottom.
Then you will be able to see the filter #11 in the diagram. It just unscrews like a cap. Get ready to catch some water.
