my refrigerator door wasn’t closing so I bought a cam kit and now it closes fine. but it doesn’t seem to be hanging square (plumb). The top of to door is too close to the freezer door and now a screw on the freezer door trim is starting to cut a groove in the refrigerator door trim. I couldn’t find anyway to adjust the door. It is just on two pin hinges. The top hinge is mounted with three bolts but I didn’t see how to adjust that. This being said it does seem to be getting worse. How do I move the top of the door over?
Is this possible to fix? Please help
Since the door hung OK before you fixed it I would say it is fixable.
The problem is without actually being there I cannot say how to fix it.
Remove the door again and re-check you repair.
Check the holes in the door that accept the hinge pins.
Check that the unit is level side to side.
Reinstall it but do not tighten the bolts all the way.
Get someone else to hold the door in the correct location and then tighten up the bolts.
