Need Schematic for dishwasher module 9000727504
Brand:Bosch
**Model Number:**SHX8PT55UC/02
Main Symptom:No start 2 lights flash NO LED Lights when door open
What happens & when:Does not start up
Does anyone know where I can find the wiring schematic or main board schematic for this machine? I need mainly to know where the LED light strip (3 contact) plugs in. It fits on top of the board, but noticed it’s only 2 strips. It pulled out and I am not sure where it goes. Those two contact leads only test for 0.24v DC on my meter, so not nearly the needed 12V DC. I don’t see anywhere else where it can plug into. On top, it is keyed for the plug. Rinse and Sanitize flash- machine won’t start. Replaced most everything else inside, except (1) modules and (1) touch panel in the upper door. Have three main modules- still not working.
Main Module is 9000727504
What is the OEM manufacturer part number that was used? The number 9000727504 is a processing number that would not reflect what the manufacturer’s part number is. For example, the manufacturer’s part number 00752744 (used with the model number that has been provided) and the manufacturer part number 00752727 both share the same number on the casing (as seen in the attached links). However, these two controls have two different programs.
Programmed control module for model SHX8PT55UC/02- 00752744 Dishwasher Control Module | Genuine Bosch OEM In Stock
Other programmed module (not for this model)- 00752727 Dishwasher Control Module | Genuine Bosch OEM In Stock
Thank you. Sorry if I was not clear. The ON light is wired fine. My question was specifically about the two INTERIOR WHITE LED lights (not floor ON lights.) The LED are supposed to light up when you open the door. I really need to understand please where these two red wires plug into. The plug has three connections, but one slot is empty so only two are used. Despite fitting (keyed), the contacts do NOT seem to line up with the copper contact patches on the module (wider apart and also way too low voltage .) This explains why no light. I really need to identify where these go, if you know please. I hope you were able to see my video. I show those wires and point to were the two red wires are currently plugged in (on top of the main module.) From the top, the LED wires are in a wide, flat cable- near the bottom, it attaches to two small red wires and a 3 prong plug.
WOW- I had no idea. Good catch! I have the original module in now- not working. All three (3) have been tried and same result. One OEM number states, “00280406.” The other TWO (2) A. Original and B. from Bosch state "EPG60651. I assume the latter is the safer bet- though NONE make it work.
I appreciate all the time and direction you have been generous to offer.
Thanks again.
Here are pics of all three control modules. Two do not drill down other than the main number and the EPG#. The original is the one in the middle , close up, large label dated 09.01.14
Please see reply in original question post. It is very possible that the two red wires for the interior lights are causing some issues with the operation of this dishwasher.
