Brand:GE
Model Number:JB250RF4SS
Main Symptom:Need personality code to set up new T09 control board.
Error Code (if any):N/A
Brand:GE
A copy:
To set up a new T09 control board, follow these steps:
Locate the Tech Sheet : This is usually found attached to the back panel of the stove or inside the oven cavity. It contains the necessary personality code for your specific model.
Install the Control Board : Ensure the stove is unplugged or the circuit breaker is off before starting. Remove the back panel to access the control board.
3.Set the Personality Code Use the instructions provided in the Tech Sheet to set the personality code for your specific model.
For more detailed instructions, you can refer to the Tech Sheet or contact support for assistance.
Hope this helps,
jeff sr.
If the old Board was Part Number WB27T11486 The Personality Setting is 32
