Brand:GE
Model Number:GTW335ASN2WW
Main Symptom:replaced control board, needs personality Id
Brand:GE
The replacement board needs to be programmed with my model’s personality ID. Unable to find instructions for this. It won’t complete cycles, the lid does not lock now, and abnormal spin cycle.
From what I am able to find, the personality ID for this model would be personality 15 as seen in the attached instructions.
WH22X38441C Instructions.pdf (209.1 KB)
Thanks, let me try that.
Tried that, didn’t work. The machine started making a really loud sound that I’ve never heard before, kinda like a drill or something.
What was the original issue that caused the main control board to be replaced?
The board went out, it wouldn’t light up and machine would not come on at all for any cycle
All the lights come on now with the new board, but it won’t operate correctly
Was the noise occurring regardless of which personality was set? Did the noise start as soon as the personality was set or did it happen after the washer was started?
Tha noise started after I applied the personality ID and pressed start. It’s like a burring noise. My husband did shut off the water to the machine, should I turn it back on?
Yes please, the noise is more than likely the water valve creating the noise due to no water being able to flow through. This can cause strain on the valve if electricity is supplied and no water source is available at the necessary pressure.
Turned water back on, and it made the same loud burring noise after it started filling up with water. I turned it back off
Would it be possible to provide a recording of the noise?
