Brand:Bosch Dishwasher Model Number:SHX88PZ55N/01 Main Symptom: What happens & when:wire came off
Error Code (if any): Parts or tests already tried: Photos / video link:
Need a little more info. What color is the wire? Do you know what component did it come off of? What we’re you working on?
four wires came off when took off door
was fixing E15 soaking water to remove code
believe wires go what cycle you want do you think i can spile
Those probably pulled out of the control board. Since Bosch doesn’t publish wiring diagrams and they are all the same color my recommendation is to replace the wiring harness (Bosch 12008387 Dishwasher Wire Harness | Genuine OEM Part)
